Date/Time: Tue, 17 Nov 2026 18:09:15 +0000
Package 11 for backtesting 6E with Numbers Bars - what data feed do I need?
View Count: 547
[2026-05-06 11:05:30]
Leon1123 - Posts: 8
I want to use Package 11 exclusively for manual backtesting of the 6E Euro FX futures using Chart Replay. No live trading. I need to replay historical sessions from 2024 and 2025 bar by bar on 1-minute charts with full Numbers Bars data including bid/ask volume and delta. Questions: 1) Is the Delayed Exchange Data Feed included in Package 11 sufficient for this, or do I need to pay additional exchange fees? 2) Does the available data include tick-by-tick bid/ask volume for 6E going back to 2024? 3) Is there any additional cost beyond the $46/month Package 11 for this specific use case?
[2026-05-06 13:29:32]
John - SC Support - Posts: 48555
1) The delayed streaming data is sufficient for your needs.
2) Yes, the data is tick-by-tick going back to around 2011.
3) There are no additional costs.
You can save some money by changing to the "Base Advanced" package rather than the "Integrated Advanced" package. As you will not be using any real-time data and if you are also not connecting to a trading service, then there is no need to be on one of the "Integrated" packages.
Refer to the information for the packages at the following link:
Description of Service Packages and Pricing: Packages
And refer to the following if you want to change your package:
Sierra Chart Purchase and License Information: Changing Package
[2026-05-06 13:45:25]
Leon1123 - Posts: 8
Hi John,
Thank you very much for your support. Please ignore my previous replies — my question is fully resolved.
Thanks again!
