Date/Time: Thu, 26 Nov 2026 04:21:41 +0000
Why is DOM Last Trade Price Box stays on even...?
View Count: 271
| [2026-05-05 16:01:02] |
| User246578 - Posts: 87 |
Hi there, 1. Why is DOM Last Trade Price Box always on even when it's not enabled? 2. And even it's enabled it doesn't let a color to be changed. It's always white, why"? 3. Is there a way to get rid of DOM Last Trade Price Box? 4. Is there a way to change a color of DOM Last Trade Price Box? Thank you |
| [2026-05-05 16:58:08] |
All of this can be done and there is no issue with hiding the Last Trade Price Box. From what you are asking, it sounds like you are trying to make changes to either the Chart Specific graphics settings, but the option is set to use the Global, or the opposite. Refer to the following: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
