Date/Time: Thu, 26 Nov 2026 04:33:40 +0000
V2903 : Trade DOM - Impossible to access the Font settings
View Count: 364
| [2026-05-04 20:27:11] |
| Sébastien - Posts: 156 |
Hi, Just for your information, with the new Graphic Setting menus released in the V2903, it seems impossible to access the Graphic Settings - Font menu from a Trade DOM. There is no link to it in the Trade DOM Chart ribbon. Therefore, it is impossible to modify the font and font size when Use Global Graphics Settings Instead of These Settings: No. Even when Copy From Global is used, it doesn't copy the font parameters to the Trade DOMs. |
| [2026-05-04 22:26:11] |
| Sierra_Chart Engineering - Posts: 25491 |
We will resolve this in the next release.
| [2026-05-06 23:34:33] |
Thank you for the update ! The new Graphics Settings windows is a huge improvement over the old one. One last remark : When modifying the Time and Sales: Grid color or width, the new parameters aren't immediately applied. To apply the new parameters, the Time and Sales Settings Show Gridlines must be turned OFF and ON. Then only the new parameters are applied. It might get some new users in trouble. |
| [2026-05-07 14:10:17] |
There have always been a few places where changes to colors/fonts does not immediately update and requires a restart of the window, or something else to force it to update. We will look into this particular one for the Time and Sales Grid, but we can not say whether it is something that can be immediately changed, as it may be a Microsoft related issue with the way the window is setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-05-12 17:35:48] |
The Time and Sales grid issue when changing the color will be resolved.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-05-13 19:36:57
