Date/Time: Thu, 26 Nov 2026 04:33:45 +0000
Can you add 2 indicators: Chandelier Exit & Volatility Stop? (FEATURE REQUEST)
View Count: 432
[2026-05-03 10:54:15]
User219560 - Posts: 4
Engineering Team:
Can you add 2 (standard) indicators: Chandelier Exit & Volatility Stop?
Date Time Of Last Edit: 2026-05-03 15:21:18
[2026-05-04 14:14:53]
Do you have information on how these are calculated? Preferably an original source.
[2026-05-05 19:11:18]
Chandelier Exit
It's an overlay on same window as chart
Would be helpful if settings have options per screenshot (attachment)
Hopefully you can reverse engineer Pinecode (attachment)
Date Time Of Last Edit: 2026-05-07 08:44:25
Private File
Private File
[2026-05-05 19:16:32]
Volatility Stop
Date Time Of Last Edit: 2026-05-07 08:44:48
Private File
Private File
[2026-05-09 16:33:50]
cmet - Posts: 747
These are simple formulas.
Chandelier Exit is Le Beau. Not sure about your settings, can't see files. Attached is the original version.
Volatility Stop is Wilder. The native SC study "Volatility Trend Indicator" is essentially the same thing.
attachmentChandelierExit.cpp - Attached On 2026-05-09 16:33:04 UTC - Size: 1.81 KB - 174 views
