Date/Time: Thu, 26 Nov 2026 04:21:35 +0000
Why Do I See a Volume Provile on SPX_CGI?
View Count: 445
| [2026-04-30 16:09:39] |
| User708541 - Posts: 215 |
I was very surprised when I applied a volume profile over my SPX_CGI chart that I was able to do this. (see image). Symbol settings even says: No Pattern Matching, Supports Market Depth = Not supported. This has me puzzled but I'm sure there is a logical answer. Where/How is Sierra pulling the data to produce a VP? Thank you. |
| [2026-04-30 17:13:28] |
A Volume Profile is determined from the volumes at each price level over a certain amount of time. The SPX_CGI symbol updates every second, which makes the data have 1 trade with a volume of 1. So if you have a 1 minute bar, you will see a Volume of 60 and the number of trades as 60. But this information is spread out over different prices, which is what the Volume by Price profile is showing you.
| [2026-04-30 19:54:23] |
To clarify, is this understanding correct? The SPX_CGI profile is effectively a time‑price opportunity (TPO‑like) profile built from 1‑lot ticks, not a true trade volume profile. So the profile shape is really: “How much time did SPX spend at each price?” More seconds at a price = more synthetic volume at that price. Fewer seconds at a price = less synthetic volume. Is this a correct understanding?
| [2026-04-30 19:58:42] |
Yes. It is exactly how much time was the price at a certain level with the volume for each bar being the number of seconds at that price. Keep in mind there is no finer increment than 1 second.
