Date/Time: Fri, 03 May 2024 05:15:38 +0000
WHY such a weak SCAN OPTION in Sierra
View Count: 10170
[2018-05-13 06:13:59] |
User164231 - Posts: 278 |
I am in love!
[2018-05-13 20:26:31] |
That is good. Hopefully the Study Summary works well for you, if that is what you are referring to.
[2019-02-03 20:35:41] |
ARDAN - Posts: 66 |
Is there any study to color study summary window out there from Sierra Chart or any other developer? Study Summary is a great tool but coloring should be done via a study. Inputs for short or long conditions should be able to be routed to the same cell. Different boolen inputs coming from different alert studies should enter a coloring study. Then they should be able to be logical AND or OR'ed each other. According to result, a single cell should be able to be painted to a color such as red for short and green for long setup/entry. |
[2019-02-03 21:07:39] |
You can definitely do custom cell coloring on the Study Summary window and this is documented here: Study Summary Window: Number, Text, and Color Control for Study Summary Subgraph Cells Each custom study can fully control its coloring. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-03 21:08:55
[2019-02-04 07:02:35] |
ARDAN - Posts: 66 |
Thanks, I've read this one. I use color bar based on an alert study to detect uptrends. I use another color bar based on an alert study to detect downtrends. So, I need a study/method to have these 2 inputs (long filter and short filter) and do coloring on the same cell, not different cells. for a chart. It is basically a logical gate which controls the color of the single cell. What would be your suggestion except developing a custom study with ACSIL which can control the background color of the study summary cells for its subgraphs? |
[2019-02-04 19:02:41] |
except developing a custom study with ACSIL which can control the background color of the study summary cells for its subgraphs? This really is the only way to do this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-04 19:02:52
