Date/Time: Thu, 26 Nov 2026 04:21:37 +0000
[Programming Help] - Alert triggered program [call] produces a command shell over chart for each call.
View Count: 329
| [2026-04-29 13:35:04] |
| Spidur - Posts: 15 |
Getting momentary flash of dialog when supplying program upon triggered alert. so, in other word in settings: globalset->alerts->Run Program when this Alert Triggered (for Alert 1) and for entry, in the value of above, enter a minimal program such as good_day_sc.exe: int main(int argc, char **argv){ return; } Result will be a blank screen dialog box over currently displayed chart when alert is called, executes and returns momentarily. The dialog box has been verified, i believe, to be from sierrachart and not my program. What i'm wondering, is this how the program is supposed to work; as it produces a dialog box for each call and if lots of alerts are being made, this will result in a flock of black screens until all such command shells exit. I believe provision to launch the command minimized could be made which should eliminate this; however, i am not sure how this would be generally supported. Currently sierra chart doc on this advises users to put a pause or getchar() call to cause the command shell, made visible to launched program, so the users may debug. If they made the launched cmd.exe/program not visible then it would be more difficult to support. But as real user with application being build around this, it's inconvenient to have our beautiful charts being blackened by popup windows. |
| [2026-04-29 22:51:35] |
| Sierra_Chart Engineering - Posts: 25489 |
This is marked as Programming Help. Maybe someone can help you with this.
| [2026-04-29 23:05:15] |
| seandunaway - Posts: 399 |
your minimal program is using window's console subsystem.. when compiling use the linker to select window's gui subsystem and use the entry point WinMain() edit: also how dare you return nothing when you declared the function returns an int :) Date Time Of Last Edit: 2026-04-29 23:16:42
| [2026-05-01 03:17:24] |
After linking with winmain()..ie., merely replace main() with int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, PSTR lpCmdLine, int nCmdShow) {} and not starting any message loop or other forms of GUI... but still a command dialog was still raised; however, this was due to a nice gesture from windows for it's opening up a "message box" in order to display standard output from batch commands i was submiting via std::system() in my code. the ntfy.sh curl was set to silent in order to stop that. so, this should be a solution to this problem. I haven't tried eliminating standard output using main() and suspect it too would have same characteristics a headlessness state would be maintained as long as you don't open standard output. |
