Date/Time: Thu, 26 Nov 2026 04:21:44 +0000
Spreadsheet
View Count: 300
| [2026-04-27 22:18:03] |
| User841161 - Posts: 357 |
I have a formula I’m using in a Sierra Chart Spreadsheet Study. The value in the cell keeps flipping back and forth between blank and the number returned by the formula. I have not seen this behavior before. I attached a short video clip showing what is happening, along with a screenshot of the formula I’m using. Could you please let me know what might be causing this? Thank you. |
| [2026-04-28 14:46:58] |
Your formula specifically states that if $AA$3 is not equal to 'QuoteBoard-CL'!a3, then return a value of "" (nothing). So what you are seeing is the direct result of your formula. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-28 15:24:32] |
But $AA$3 does equal to 'QuoteBoard-CL'!a3, hence why it is giving me 'QuoteBoard-CL'!R3 which is equal to 22. It gives me 22, but flips from blank to 22 every few seconds? Shown in mp4 file I sent..
| [2026-04-28 17:57:43] |
The implication is that it is NOT equal at the times when the field goes blank. If the value in AA3 always equals 'QuoteBoard-CL'!a3, then what is the reason for the IF statement in that location? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-30 14:12:50] |
ok, in asking your question, made me think about my formula. I rewrote it, in simpler version, to do the same thing- =INDEX('QuoteBoard-Cl'!R2:R15, MATCH(AA3, 'QuoteBoard-Cl'!A2:A15, 0)). It still lists correct data for few seconds and then flips to #N/A- back and forth.
Private File |
| [2026-04-30 15:06:11] |
There is something wrong with your formula that it is giving the #N/A sometimes. Most likely it is when the result of the MATCH is not found, which gives a result of #N/A, which will then give a problem for the INDEX() function.
