Date/Time: Thu, 26 Nov 2026 04:21:40 +0000
discrpancy between Real time and clock overlay study
View Count: 297
| [2026-04-27 20:07:23] |
| HAL9000 - Posts: 8 |
Hi, not sure why there's a appx 7sec time delay between "real time" and the clock overlay study on the DOM
| Attachment Deleted. |
| [2026-04-27 20:58:28] |
This is because the "Clock - Real-Time" uses your computer clock to get the time. Therefore, the difference in times is due to your computer clock being off the standard by the amount you are seeing. You can use Sierra Chart to set your computer clock to keep it accurate. Refer to the following: Network Time Protocol Client For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
