Date/Time: Thu, 26 Nov 2026 04:21:37 +0000
Two separate Prop firm accounts
View Count: 285
[2026-04-27 18:46:37]
User357195 - Posts: 204
If I have one prop firm account at Company A and another prop firm account at Company B, what is the quickest way to switch between these two? Right now, I have to reenter the Server(List) and my Trading username and Trading password for each account and then reconnect Sierra Charts to the Rithmic feed.
[2026-04-27 20:44:13]
Our recommendation is to use two separate installations of Sierra Chart on the same computer. In this configuration, you will have one connected to one Prop Firm, and the other to the other. As long as this is done on the same computer, there are no additional fees from Sierra Chart.
Refer to the following for how to install an additional Sierra Chart:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
