Date/Time: Thu, 26 Nov 2026 04:21:44 +0000
chart border ?
View Count: 488
[2026-04-27 13:04:01]
zippyzip - Posts: 310
is there a way to wrap the chart scale border around whole chart ? seems to be missing the top on current versions
Private File
[2026-04-27 18:13:50]
There is no line at the top of the chart for the "Chart Border".
We are curious as to how that chart is displayed, as you should have a the window border being drawn at the top of the chart, so the line for the "chart border" at the top of the chart should not matter.
[2026-04-27 18:22:37]
its just main chart on chart book not detached but all my charts detached do the same so not sure , it had a border on prev versions i was using so not sure
[2026-04-27 19:12:49]
You can control the windows border color for attached charts since earlier this year. Perhaps you have this set to a color that is not obvious. Refer to the following and the 3 items below it:
Graphics Settings: Window Title Bar
[2026-04-27 19:24:50]
i found it but def dosent do anything to that part of chart
Private File
[2026-04-27 20:49:57]
Also note the graphics setting for "Window Border" and "Window Inactive Border" down just a bit from the other ones we referenced.
But, we really are not understanding how you have that empty space between the graph area and the control bar that is displayed. Something is causing that large space, which is what is really the issue.
Do you have your Main Price graph set to display in a different region than the main region (region 1)? Or are there other control bars that we can not see?
[2026-04-28 15:26:43]
here is chart scale boarder setting that used to wrap all the way around charts border , i set to blue and 25 width to show u , there is nothing on top of border anymore just blank open space. attached and detached do same thing . please advise
Private File
[2026-04-28 17:59:39]
What you show in the most recent image makes sense. You are changing the "Chart Scale Border". There is no "top" line to that Chart Scale Border. Rather, the top of the chart itself defines where that occurs.
[2026-04-29 13:04:49]
ok but u can clearly see there is issue there theres not frame to the chart , it was there before the update to 2899 is all im saying . that scale border wrapped all the way around
Private File
[2026-04-29 13:11:46]
also the region divider lines do not show up so assuming there is similar issue with both
[2026-04-30 15:27:22]
[2026-05-01 19:37:16]
Sierra_Chart Engineering - Posts: 25489
Regarding the first post, when windows are attached and in the main window, there is a different implementation of these windows. Why you do not see a line at the top we do not know but that was never drawn by Sierra Chart. We suspect it was a border drawn by the operating system for the control bar sub window. Why it is not there now, we do not know. And under no circumstances, would we ever do anything to cause the operating system to draw it again because the color cannot be controlled by Sierra Chart.
The region dividing lines still work. This is the option:
Chart Settings >> Grid >> Display Region Dividing Lines : Yes
Date Time Of Last Edit: 2026-05-02 03:12:28
