Date/Time: Thu, 26 Nov 2026 04:21:38 +0000
[User Discussion] - Does anyone use SierraChart for equities?
View Count: 443
| [2026-04-26 22:22:36] |
| User558370 - Posts: 26 |
Im liking how i can customize it for futures... but it sure did take a LONG time to figure out Does anyone use it for equities like NASDAQ tickers... NVDA, AMD, PLTR etc? Is it a road worth going down? Also, is there a hotkey/short cut to toggle between different time frames? |
| [2026-04-27 16:14:26] |
Refer to the following: Changing Chart Bars Period For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-27 21:13:54] |
| Sierra_Chart Engineering - Posts: 25489 |
Yes Sierra Chart can be used for charting Equities. Refer to this data feed: US Stock/Equities Consolidated Tape Data Feed You can also trade Equities through Interactive Brokers: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-27 21:15:06
