Date/Time: Thu, 26 Nov 2026 04:11:49 +0000
Custom Symbol Setting pattern match
View Count: 274
| [2026-04-25 02:23:24] |
| enemyspy - Posts: 307 |
Will making a custom symbol setting with just this: ~ Apply that setting to every symbol? Just want to make sure. Thanks. |
| [2026-04-25 22:46:41] |
| Sierra_Chart Engineering - Posts: 25489 |
No this is not going to match with every symbol. All of the existing Symbol Settings, will take precedence over this. And it does not make sense to have one symbol setting that matches with all symbols anyway. That is going to cause serious problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
