Date/Time: Thu, 26 Nov 2026 04:11:37 +0000
FootPrint chart does not shows values when I replay. Why?
View Count: 313
| [2026-04-22 21:15:37] |
| User759540 - Posts: 5 |
Hi I am using a foot print chart and want to replay the chart at a slower pace. However, when I replay the chart, I do not see any values on the chart and it is just blank screen. |
| [2026-04-22 21:31:56] |
We wonder if you are trying to start the replay from a point in time before you actually have data in the chart. You need to have the data loaded first, then you can run the replay from that point in time. Refer to the following: Replaying Charts: Use Start Date-Time For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
