Date/Time: Thu, 26 Nov 2026 04:11:48 +0000
NASDAQ TotalView
View Count: 359
[2026-04-21 11:38:35]
more - Posts: 154
Hello, I don't see some stocks in NASDAQ TotalView, such as Broadcom Inc.(AVGO), ASML Holding (ASML), Costco Wholesale Corp (COST).
Is it possible that they aren't there? Thanks
image1...PNG / V - Attached On 2026-04-21 11:38:12 UTC - Size: 24.68 KB - 219 views
image2...PNG / V - Attached On 2026-04-21 11:38:23 UTC - Size: 23.65 KB - 211 views
[2026-04-21 19:34:52]
The list of NASDAQ TotalView stocks is not comprehensive. If you want a symbol that is not listed, then you need to type it into the "Selected Symbol" field - such as "ASML-NQTV".
