Date/Time: Thu, 26 Nov 2026 04:11:42 +0000
Denali Historical Data with Rithmic Trade Service Setting
View Count: 569
[2026-04-20 23:00:25]
User845712 - Posts: 10
I am trying to load a daily(historical) chart for NQ to see data going back 20+ years.
I currently use Rithmic Direct - DTC as the "Current Selected Service" under Data/Trade Service Settings. It is my understanding that I can still use Denali historical data with Rithmic as my trade service as long as 1. Market Data Username and Password are blank 2. Data/Trade Service Settings>Common Settings> Common Other Settings>Allow Support for Sierra Chart Data Feeds is set to "YES".
When I load a daily chart for NQ with these settings, I can only see data back to 2020. Im assuming that this is because data is being pulled from Rithmic instead of Denali. When I change "Current Selected Service" to "SC Data" I can then see data on my daily chart all the way to the year 2000 and beyond. I have my chart settings>Data Limiting - Number of Days to Load set to 5250, and Symbol>Continuous Contract set to Continuous Futures Contract - Volume Based Rollover.
I know other users have been able to successfully use this setup, but I cant figure it out. Appreciate any help you can provide.
image1.png / V - Attached On 2026-04-20 22:58:19 UTC - Size: 10.89 KB - 185 views
image3.png / V - Attached On 2026-04-20 22:59:01 UTC - Size: 41.37 KB - 166 views
image2.png / V - Attached On 2026-04-20 22:59:08 UTC - Size: 28.84 KB - 187 views
[2026-04-21 18:40:00]
The reason you can only go back to 2020 when connected to Rithmic is due to the single digit year that Rithmic uses in their symbols. Due to this, you are limited to just 5 years of historical data.
[2026-04-21 19:28:40]
THanks for the response John. Are there any workarounds you could suggest, besides the obvious "Dont use Rithmic"?
[2026-04-21 19:59:13]
There are no workarounds. Since it is a single digit year in the symbol, we limit the data to 5 years for Rithmic.
