Date/Time: Thu, 26 Nov 2026 04:11:39 +0000
Account Reminder
View Count: 297
[2026-04-20 16:40:29]
User257833 - Posts: 1
I am using Sierra Chart with AMP Futures and I would like to simplify my
chart candlesticks display.
My goal is to have a very minimal visual panel on the chart showing only:
- Current account equity
- Current time
- Current Bid price
- Current position (Buy / Sell / Flat)
I do NOT need the full Trade Window or large panels.
Is there a built-in way to configure a minimal on-chart display with only
these elements?
If not, what would be the recommended approach to implement a lightweight
custom panel using ACSIL?
Thank you.
[2026-04-20 16:47:01]
Refer to the following study that allows you to display information for a subgraph. You would use multiple copies of this to display the particular information you want.
Text Display For Study
You would just have to determine where to get the specific data you want. For instance, to get the "Bid Price" you would use the "Bid and Ask Prices" study and then display the "Bid (SG1)" subgraph using the above study whereever you want to put it.
Although for the time, there is the following study:
Clock - RealTime
We are not sure what you are looking for in terms of the "Current Account Equity". If you are referring to your Account Balance, then this is not directly available within Sierra Chart.
In terms of using ACSIL, you can use the "Text Display for Study" as a template for how to do this. The study function is called "scsf_LargeTextDisplayForStudy" and is available in the Studies3.cpp file in the ACS_Source folder under your main Sierra Chart installation folder.
