Date/Time: Thu, 26 Nov 2026 04:11:42 +0000
Sierra Chart DOM highlight box not matching cell height
View Count: 518
| [2026-04-19 15:09:25] |
| User245317 - Posts: 2 |
I’m seeing a visual issue in Sierra Chart DOM. The highlight box does not fully align with the row height and does not cover the cell properly. I would prefer not to change the font size, because the current font size is fine for me. What I want is simply to align the highlight/hover box with the cell size so it matches the row height that I set manually. Is there any way to fix this, or is this just a limitation of how the DOM is rendered? |
| Attachment Deleted. |
| [2026-04-20 14:29:32] |
We are not understanding your issue relative to the image you provided. We do not see any misalignment with any of the items in the image, so we are not sure what item, in particular, you are referring to. Please let us know what item in the image you provided you are referring to, or get us another image with the item showing - and let us know what item specifically you are referring to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-20 14:41:52] |
sure, just attached another image, I selected in the frame and the empty space between the backlight and the grid line.
| [2026-04-20 14:55:04] |
This is just how these items are rendered, and it is not something that we would be changing.
