Date/Time: Thu, 26 Nov 2026 04:11:44 +0000
VBP showing decimal
View Count: 423
| [2026-04-18 16:39:31] |
| User449884 - Posts: 238 |
My vbp has been showing volume in the DOMs with about 12 digits after decimal point. This has happened after upgrade to 2898
| [2026-04-18 18:56:55] |
| Sierra_Chart Engineering - Posts: 25489 |
This is because you are using a Volume Multiplier in the Chart Settings ? We are adding a Volume Value Format setting in the next release which we are putting out in about 30 minutes. You will want to set this to 1. Which will be the default. This will be version 2900. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-18 19:20:38
| [2026-04-19 20:30:08] |
im using the standard VBP study and using volume qty instead of bars but nothing else
| [2026-04-19 20:41:11] |
Update Sierra Chart to version 2900. Instructions: Software Download: Fast Update This is the Prerelease. The problem will be resolved. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-19 20:41:29
| [2026-04-20 14:40:02] |
thanks
