Date/Time: Thu, 26 Nov 2026 04:11:36 +0000
Chart Settings/Performance tab
View Count: 408
| [2026-04-18 07:26:18] |
| eerivera - Posts: 8 |
The Performance stats are greyed out. This is a tab of the Chart Settings Window. Can you tell me why and how to fix it?
| [2026-04-18 18:47:45] |
| Sierra_Chart Engineering - Posts: 25489 |
They are read-only. So they will be in a different color. But they still will show values.
| [2026-04-18 22:42:58] |
They have always been not greyed out, what is the way to get it back?
| [2026-04-18 23:46:20] |
There should be separate color settings to control the read-only value colors for settings windows. We will make sure those are added.
| [2026-04-19 00:23:09] |
So something happened in the Color Settings Windows, it is not actually a change in the functioning of the Performance Tab from one state to another?
| [2026-04-19 00:25:29] |
Is your copy of Sierra chart also having this in Grey?
| [2026-04-19 06:15:38] |
These are the settings that control the colors for those read-only lines: Graphics Settings >> Settings Windows: Read-Only Setting Description Foreground Color Graphics Settings >> Settings Windows: Read-Only Setting Description Background Color We are going to add two more to control, the value color separate from the description/name. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-19 07:21:48] |
The problem is that I loaded the latest version. I went back to the previous version and everything is working again. The Performance Tab is like it was.
