Date/Time: Thu, 26 Nov 2026 04:11:46 +0000
Line to connect all top or bottom
View Count: 376
[2026-04-17 21:00:44]
Lilydo - Posts: 18
I'm using Color bar study to take some bottoms. Do you know with study that I can connect all these bottoms?
Thank you
Private File
[2026-04-17 21:56:08]
Are you wanting a line what you have drawn in the image, or just a straight line connecting between the points?
[2026-04-17 23:33:41]
Lilydo - Posts: 18
Hi, I want automatic drawing the dash stair step to connect red point on low
[2026-04-20 14:10:06]
There is no option like that within Sierra Chart.
The only way to get something like that would be to create a custom study that draws each straight line segment as an individual line. Refer to the following:
Using Drawing Tools From an Advanced Custom Study
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
[2026-04-20 15:39:17]
Lilydo - Posts: 18
I used Color bar condition study to make the red point and then used spreadsheet to create the dash stair step. It worked but I don't know why sometimes the dash line show up sometimes not. What do you think?
[2026-04-20 19:56:30]
When it is not showing, you would need to look at the data in your spreadsheet and make sure everything is correct. But other than this, we have no insight as to why you would have an issue.
