Date/Time: Thu, 26 Nov 2026 04:11:41 +0000
Cannot Load Data for Nasdaq Composite
View Count: 522
| [2026-04-15 05:33:26] |
| User873664 - Posts: 18 |
Hello, I cannot load a chart for the Nasdaq Composite using barchart symbols. I see the symbol here https://www.barchart.com/stocks/quotes/$NASX/overview, but when I enter that as the chart symbol I got the following error: Download Failed Error downloading historical daily data for $NASX. Error: user is not authorized to execute query for one or more of the specified symbols Other barchart symbols seem to work fine for example another one I picked $SSCO. Appreciate any help you can provide for this, I am trying to load the daily chart for the Nasdaq Composite. |
| [2026-04-15 07:06:13] |
| Sierra_Chart Engineering - Posts: 25489 |
This data is not available. NASDAQ charges a lot of money to access that data. It is just simply not available at this time. We will consider offering it in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-15 07:06:45
| [2026-04-15 15:03:37] |
Hello, I can go on tradingview and access this information for free with the symbol IXIC. Is there anything that can be done? EOD data is fine. I do realize now that I can load ONEQ which is probably fine. |
