Date/Time: Thu, 26 Nov 2026 04:11:39 +0000
Custom study disappears from the dom when I try and put a custom study on chart.
View Count: 419
[2026-04-14 20:00:04]
Island_Trader - Posts: 37
I have my dom, chart and tape setup with a custom study on the dom utilizing both custom columns. When I try and add a custom study to the chart the dom study dissapears. Would the chart linking cause this? Trying to figure out why so that I can setup a custom study on my chart.
[2026-04-14 21:00:35]
If you have Chart Linking setup with the "Studies" option enabled for both the Trading DOM and the Chart, then this would cause what you are seeing. Refer to the following:
Chart Settings: Chart Linking >> Studies (Chart >> Chart Settings >> Linking menu)
If not the above, then is the study on the Trading DOM actually being removed from the Trading DOM when you add a study to the Chart, or is the study still there, but not working correctly?
