Date/Time: Thu, 26 Nov 2026 04:11:45 +0000
Time displayed in the DOM
View Count: 492
[2026-04-14 17:27:47]
User647607 - Posts: 21
Hello -
I set up a DOM a while back. In it, it displays the time at the very top next to DPL. I'd like to replicate this in my other DOMs but I don't know how I did it. I do not have any studies enabled on that DOM. I've included a screen capture. Thanks for your help.
Date Time Of Last Edit: 2026-04-14 17:28:15
imageScreenshot 2026-04-14 123028.png / V - Attached On 2026-04-14 17:26:24 UTC - Size: 18.79 KB - 196 views
[2026-04-14 18:00:48]
Given that location, that would have to be the "Clock - Realtime" study. Refer to the following:
Clock - RealTime
Just so you are aware, there is also an option to display the Time in the Chart Header. It looks like you are not displaying anything in the chart header, as this would be a line above the DPL:. Refer to the following if you want to use this option instead:
Global Settings Menu: Customize Chart Header - Trade DOM (Global Settings menu)
