Date/Time: Thu, 26 Nov 2026 04:11:45 +0000
mouse pointer
View Count: 452
| [2026-04-13 20:35:00] |
| User473031 - Posts: 73 |
There seems to be an offset between what I point too on the dom or chart and how SC reads it. For example if I point and clicked the dom 22540 , it will interpret it as 22545. Same with adjust drawings or regions. I've looked for offset but haven't come across anything that would explain what I'm seeing. |
| [2026-04-13 21:41:37] |
Given what you have stated, this would be an operating system issue. There is nothing we can do to help with this. Our only suggestion is to reboot your system and see if the issue resolves that way. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-13 21:43:58] |
Thank you, First thing I did was reboot the system. It didn't solve anything. It's only an issue with SC. and no other applications. |
| [2026-04-14 14:04:34] |
Another thing to try is a different pointing device and see if it makes any difference.
