Date/Time: Thu, 26 Nov 2026 04:11:45 +0000
no replay
View Count: 283
[2026-04-13 19:48:38]
User580305 - Posts: 4
Hello , in the past i used my replay mode chart with no problem, today when i try to use chart replay mode it download teoretycly -becouse in real tha chart re-download but with cuurrent date not the one i put for example 2026-04-22 its not downloading the chart stays in the same date , when i try to play it prompt me with free question with clearing data or not but it again nothing happened the chart is restarting , why what happened i downloaded the current version.
Sincerly
[2026-04-13 19:50:25]
When running a Replay, you have to have the data already loaded in the chart. If you are trying to start a replay at a point in time prior to where the data exists in the chart, then it will start from the earliest data you do have in the chart - not the point where you want it to start from.
This is why we recommend scrolling back to where you want to start, instead of using the "Start from Data-Time" option. Refer to the following:
Replaying Charts: Replaying Chart from Specific Date-Time
