Date/Time: Thu, 26 Nov 2026 04:01:36 +0000
jose manuel berrocal duarte
View Count: 254
| [2026-04-13 19:24:58] |
| User927032 - Posts: 1 |
Estoy intentando utilizar numbers bars pero los numeros me salen con decimales, tengo el sierra chart en el portatil y me salia bien y en el PC no, me he dado cuenta que en el portatil tengo la opcion de volume value format list y en el PC no me sale esa opcion, esa es una imagen del portátil la línea de volume valué format list en el PC no existe, y esta exactamente todo igual y la segunda es la del PC
Private File |
| [2026-04-13 19:26:11] |
From Google Translate: I am trying to use Number Bars, but the figures are displaying with decimals. I have Sierra Chart installed on both my laptop and my PC; it worked correctly on the laptop, but not on the PC. I noticed that on the laptop, I have access to a "Volume Value Format List" option, whereas that option does not appear on the PC. The first image attached is from the laptop—showing the "Volume Value Format List" line—while that line is completely missing on the PC; yet, every other setting is configured exactly the same way. The second image is from the PC.
We need to see an image of the chart that shows the decimal places. Please follow these instructions to get us an image: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) Also, we need to know what version of the software you are running on that specific system, along with the symbol of the chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
