Date/Time: Thu, 26 Nov 2026 04:01:31 +0000
Data feed not refreshing
View Count: 484
| [2026-04-13 13:30:58] |
| User427554 - Posts: 2 |
I have live data feed from Teton CME routing to my Sierra Charts. The Sierra charts says the feed is connected - green bar at top left hand side of page. However my charts are not updating with new data as each new tick should be coming in. Can you help please? I am trading with Stage 5 / Dorman.
Date Time Of Last Edit: 2026-04-13 13:48:27
| [2026-04-13 14:17:19] |
Everything on your account looks good, so you should be getting the real-time data. In this case, please go through the items at the following link: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-13 14:31:50] |
I discovered that I had a Sierrachart session still open on an old VPS I cancelled 9 days ago, so I just closed that down and now my normal Windows session works OK with live data feed. THanks for your prompt response!
