Date/Time: Thu, 26 Nov 2026 04:01:29 +0000
error downloading pre release
View Count: 223
| [2026-04-13 00:13:54] |
| User953554 - Posts: 20 |
hi I keep getting an error when updating to newer version via the help menu. I created a log which it says has been sent to you. My version updates it's just that it has been giving me an error popup each time saying something like ' download completed with errors" |
| [2026-04-13 14:07:44] |
| Sierra_Chart Engineering - Posts: 25489 |
Try using the ZIP installer instead: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-13 14:08:12
