Date/Time: Thu, 26 Nov 2026 04:01:33 +0000
Feature Request: Duplicate Window with Independent Chartbook Set
View Count: 342
[2026-04-11 04:28:12]
Piotr Grzegorzek - Posts: 36
I would like to request a new feature related to window management.
Currently, it is possible to open additional instances of Sierra Chart, but this creates separate instances where drawings and chart data are not shared between them.
Requested functionality:
> Ability to duplicate the main Sierra Chart window (within the same instance),
> Each duplicated window should allow opening a different set of Chartbooks,
> While still sharing the same instance data (including drawings, studies, and chart data).
I currently use:
> one instance per instrument (CL, GC, YM, RTY with m1, m5, m15, m240, d1 charts),
> plus one additional instance with multiple instruments in a single Chartbook (m1 charts for CL, GC, YM, RTY for overview).
However, using multiple instances causes an issue where drawings are not synchronized between instances, which makes workflow more difficult.
Having the ability to duplicate the window within the same instance, but load different Chartbooks, would allow:
> consistent drawings across all charts,
> better multi-monitor workspace management,
> reduced need for multiple instances.
Thank you for considering this request.
[2026-04-11 21:21:08]
Sierra_Chart Engineering - Posts: 25489
Support for multiple main windows, one for each Chartbook, is coming. We hope to have it done this year but we are not totally sure.
