Date/Time: Thu, 26 Nov 2026 04:01:30 +0000
Replay Chart - Unable to see trades on Statistics
View Count: 477
| [2026-04-10 18:45:10] |
| User288032 - Posts: 3 |
Hi, I have completed quite a few Replay Trades which are lsited in the Statistics sheet but all the ones I have done this week haven't appeared. Can you look into this please. Thanks |
| [2026-04-10 18:46:39] |
All of the information for your system is on your local computer. We do not have any access to this information. Most likely, you do not have the correct filters set for the "Trade Activity Log" for those trades. Check the "Display Settings" and make sure everything is set properly. Refer to the following: Trade Activity Log: Common Instructions to Set Trade Activity Log Display Settings For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-11 10:06:44] |
This is the set up I have - No order fills showing for the past 7 days. Setting Name Values Trade Activity Type (List) All Activity Symbol (List) All Symbols Trade Account (List) All Accounts Simulation State (List) Simulated Date Range to Display From date 01/10/2025 From time 00:00:00 To date (Read only) End To time (Read only) 19:00:00 To Date - Time is Today Yes (Button) (Set to todays Date} Internal Order ID (List) All Internal Order ID's Note (List) All Notes Profit Loss Display Format (List) Currency value (C) Order Action Source Search Text Use name Filter Period Stats Tab Period Type (List) None Use Commission No Always Perform Query on Apply Yes (Button) (clear Trade Activity) Current Query Count (Read Only) 0 Any Ideas? |
Attachment Deleted. |
| [2026-04-11 15:52:25] |
| Sierra_Chart Engineering - Posts: 25489 |
See if you actually have trade activity for the particular date and trading account, with data: Trade Activity Log: Determining Existence of Trade Activity through Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
