Date/Time: Thu, 26 Nov 2026 04:01:34 +0000
Inquiry About Implementing Click-to-Move Order
View Count: 421
[2026-04-10 18:05:44]
Antonio Costarella - Posts: 1
I would like to ask if it is possible to implement, within Sierra Chart, a feature similar to the “click-to-move” order functionality available in Jigsaw Daytradr.
Specifically, I am referring to the ability to modify an existing order (such as a limit order or stop loss) by simply clicking on a price level in the DOM, causing the order to instantly “jump” to that level, without the need for drag & drop.
I understand that Sierra Chart offers advanced customization through ACSIL. Could this type of behavior be developed using ACSIL, custom studies, or trading buttons? If so, are there any existing examples, documentation references, or recommended approaches to achieve this?
This functionality is particularly important for fast market conditions, where speed and precision in order management are critical.
Thank you in advance for your support.
Best regards,
[2026-04-10 18:08:33]
This ability exists in the system. "Move Targets to Price" and "Move Stops to Price" are options that can be setup for the Right/Left click options in the Buy/Sell columns. Refer to the following:
Global Trade Settings Windows: Order Types (Global Settings >> Chart DOM Settings)
