Date/Time: Thu, 26 Nov 2026 04:01:31 +0000
Global position Limit
View Count: 313
| [2026-04-10 17:05:41] |
| User154012 - Posts: 3 |
Hello, I am having an issue on Sierra Chart with my trade window. My order size is blocked at 2 contracts maximum, and every time I try to increase above 2, I get the following message in the Trade Service Log: "Trade Order Error - Order will cause Global Position limit of 2 to be exceeded." I believe this limit was configured previously in Sierra Chart settings, but I can no longer find where to modify or remove it. Could you please tell me exactly where this Global Position Limit setting is located so I can increase the maximum number of contracts? Thank you in advance. Best regards, Henrique |
| [2026-04-10 17:17:49] |
Refer to the following: Global Symbol Settings: Use Global Trade Position Limit (Global Settings >> Symbol Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
