Date/Time: Thu, 26 Nov 2026 04:01:34 +0000
the Confirm Order popup notification
View Count: 564
[2026-04-09 14:46:15]
User65931 - Posts: 28
opens in the middle of the screen,
which means I cant see it behind a "Window Always Visible" chart.
Is it possible to make popups open on the left side of the screen?
Or, is it possible to make popups Always Visible?
[2026-04-09 15:21:22]
There is no way to make the popups show on the left side of the screen, or to make them "Always Visible".
It sounds like you have the window set to "Always on Top" (not necessarily "Always Visible"). With "Always on Top", the window will always be on top - you are specifically setting it to be on top of everything else, therefore what you are seeing is going to happen.
[2026-04-10 12:10:33]
OK, currently SC cannot do this.
But it is possible to do for example:
Application-Specific Popups (AutoCAD, BlueNote, etc.)
Save Position: Many applications have built-in functionality to remember window locations. Simply drag the popup to the desired corner or side of the screen and close it. When it reappears, it should be in that new location.
"Top-Left" Method: If a popup consistently reappears in the middle of the screen, drag it to the top-left corner and close it to reset its default position.
[2026-04-10 17:51:58]
I should clarify that the "Always on Top" chart1 occupies 60% of the monitor, so I simply want to permanently reposition pop-ups to show up somewhere on the remaining 40% space of chart2 when I interact with Chart2.
Of course, Chart2 is not set to "Always on Top".
