Date/Time: Thu, 26 Nov 2026 04:01:38 +0000
How do I place a Sell Order directly at Fibonaci Levels ??
View Count: 495
[2026-04-09 03:48:13]
LogicX64 - Posts: 1
I use Fibonacci projection on 5-minute Candle LOW & High to find my Sell Entries.
After that, I manually move my mouse to that Fibonacci level and right-click to set my Sell order.
I want to skip that last step. How do I place my SELL order immediately after I use fibnoacci???
Please help. Thank you.
[2026-04-09 14:32:55]
The best way to do this would be to create a custom study. Refer to the following:
Using Drawing Tools From an Advanced Custom Study
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
A way to somewhat automate what you want would be to use two copies of the "Spreadsheet Formula" study along with the "Spreadsheet Study for Trading".
You use the "Spreadsheet Formula" studies to get the anchor points of the drawing you want. Refer to the following:
Study/Chart Alerts And Scanning: Reference by Anchor
You would need to calculate the particular level you want based on those anchors in the Spreadsheet System itself.
Then you can set the level where you want the order in the "Limit Or Stop Price" field in the spreadsheet. Then when you want to place the order, you would set the "Buy Entry" cell to a non-zero value.
