Date/Time: Thu, 26 Nov 2026 04:01:37 +0000
how do I add "2 Minutes" to chart shortcut menu
View Count: 513
| [2026-04-08 17:46:38] |
| MMX - Posts: 123 |
| [2026-04-08 19:23:41] |
If you are asking for a "2 minute" bar period, then there is not a way to add this to the "Chart Shortcut Menu". There are only the pre-set items that can be set for that. You can setup custom time bar periods for Control Bars. Refer to the following: Control Bar: Custom Buttons for Intraday Chart Bar Period But refer to the following for a quick way to change a bar period from the keyboard, and also note the other ways to change the bar period on that page: Changing Chart Bars Period: Fast Changing by Keyboard For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-09 07:55:35] |
| MMX - Posts: 123 |
OK, just thought I would ask, I really like right clicking for my 5 and 10 minute charts. My 2 minute chart is in control bar 2 and has been there for years.
