Date/Time: Thu, 26 Nov 2026 04:01:32 +0000
Question about (CQG) Data Feed
View Count: 493
[2026-04-08 02:28:30]
User252013 - Posts: 1
I'm looking into trading the OSE Nikkei 225 futures (micro/mini) - are there any other data providers supported by SC which provide level 2 data for OSE other than CQG?
Additionally, if I am only looking to backtest/sim trade for now, would I have to get service package 10+ as I am using a 3rd party data provider, or would package 5 suffice? Thanks in advance.
[2026-04-08 13:37:31]
Sierra Chart only has connectivity with Interactive Brokers, and brokers that use Rithmic, CQG, or Teton for their order routing. As such, the only other recommendation would be to check and see if you can get what you want with Interactive Brokers.
We are not sure what you mean by you are using a 3rd party data provider - but in general, in order to be able to connect to data providers, you would need to be on one of the "Integrated" packages. Refer to the following:
Description of Service Packages and Pricing: Packages
