Date/Time: Thu, 26 Nov 2026 04:01:34 +0000
Chart ES and Trade MES Problems
View Count: 458
| [2026-04-07 15:58:02] |
| User442831 - Posts: 3 |
Hello Support, I have had problems with trading MES on an ES chart consistently over the last few months. I have done this for years without any issues until recently this year. I have the following configuration: Chart > Chart Settings > Symbol Symbol (Action) = ESM6.CME Trade and Current Quote Symbol (Action) = MESM6.CME Use As Trade Only Symbol = Yes But for some reason I end up trading ES. What else do you need from me to help me figure this out? |
| [2026-04-07 17:12:49] |
Why do you state that you are actually trading the ES? Is this what you see in the Trade Activity Log, or with your broker? If the issue is the Profit/Loss values, then this would mean that you do not have the "Currency Value per Tick" set properly. Refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2026-04-13 15:48:05] |
Thanks, John. This was a user issue. Appreciate the quick response.
