Date/Time: Tue, 24 Nov 2026 18:00:51 +0000
Trading ICE (Europe & U.S.), Euroenxt and MEFF
View Count: 418
| [2026-04-07 10:36:22] |
| User758540 - Posts: 4 |
I have reached out to my broker to see if the following are available to trade and they said to confirm with you regarding the following. Can you confirm if 1) I can get data and 2) Trade the following products - Sugar (ICE Europe & U.S.) Coffee (ICE Europe & U.S.) Cocoa (ICE Europe & U.S.) CAC (Euronext) AEX (Euronext) IBEX (MEFF) I am currently trading Eurex and CME using Denali data feed with CQG for ordering routing. Can you confirm if the above queried products could be traded via the same way (i.e. Denali + CQG order routing)? Thank you. |
| [2026-04-07 10:40:43] |
| Sierra_Chart Engineering - Posts: 25476 |
CQG should support all of these exchanges. In this particular case you will use CQG and you need to use the market data from CQG. Just have your broker enable the exchanges on the CQG side for all of those exchanges. In this case, the market data will then come from CQG. The Denali Exchange Data Feed does not provide data for those exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-07 10:41:21
| [2026-11-24 16:29:13] |
| DDC - Posts: 37 |
A follow up on this thread. Are there any plans for Denali to provide data for the ICE exchange?
