Date/Time: Thu, 26 Nov 2026 04:01:36 +0000
ReadIntradayFileRecordForBarIndexAndSubIndex always returns 0
View Count: 438
[2026-04-07 00:14:50]
coachted - Posts: 545
I have a custom ACSIL study built as an external DLL using Visual Studio. I am calling ReadIntradayFileRecordForBarIndexAndSubIndex but it always returns 0 regardless of settings.
My diagnostics show:
FileRecordIndexOfLastDataRecordInChart = 19307381 (file exists and has records)
ArraySize = 1438
ChartDataType = 2 (intraday)
IntradayDataStorageTimeUnit = 0 (this seems wrong)
Intraday Data Storage Time Unit in Global Settings = 1 Tick
Sierra Chart version 2888, revision 55876
Data feed: Rithmic via DTC
Symbol: ESM6.CME (non-continuous)
The scid file exists at C:\SierraChart\Data\ESM6.CME.scid and is 736MB.
Questions:
Why does IntradayDataStorageTimeUnit report 0 when Global Settings shows 1 Tick?
Is there anything required in SetDefaults to enable intraday file record access for an external DLL?
Is ReadIntradayFileRecordForBarIndexAndSubIndex supported for externally compiled DLLs with Rithmic/DTC feeds?
[2026-04-07 09:22:02]
Sierra_Chart Engineering - Posts: 25489
Show us the parameters you are using when calling this function:
sc.ReadIntradayFileRecordForBarIndexAndSubIndex
This means 1 Tick.
No definitely not.
Yes. Nothing special is needed for this.
