Date/Time: Sun, 18 Oct 2026 18:39:20 +0000
[User Discussion] - Is it possible to quickly create a chartbook with specific chart windows by editing a text file?
View Count: 1274
[2014-10-27 19:49:11]
User59863 - Posts: 36
Instead of the laborious way via 'Duplicate chart' etc?
Other than product & timeframe, chart settings & studies would be identical for all windows
I have over 200 windows in a chartbook.
Plus multiple windows are various timeframes of the certain products.
[2014-10-28 13:24:52]
Futures Operator - Posts: 239
You can Save As and rename an existing Chartbook to duplicate it, and then work with the new copy.
[2014-11-02 19:12:58]
Where's Sierra on this?
Not what I was asking
If I have a chartbook with 20 windows & I want to QUICKLY & EFICIENTLY add 100+ more symbols (with the same studies but with different timeframes / products) then it will take forever via "Duplicate chart" etc
Not efficient.
I want to know if i can create a text file & BULK EDIT it (efficiently add products/replicate chart studies), as a shortcut
Where are the files location where data on chart studies for each instrument etc are stored?
(I see in the /data folder there are a bunch of separate .DLY files - no good to me)
