Date/Time: Thu, 26 Nov 2026 04:01:28 +0000
Missing Linking Types [Bug Report]
View Count: 415
| [2026-04-04 18:21:53] |
| Daniel - Backtesting.club - Posts: 177 |
Hello, The chart window linking settings do not offer the same options across platforms (see my screenshot). This is quite confusing, because unless a user goes directly to the Chart Settings window, they won’t even know about some of the linking options. The Symbol List option is missing in Chart > Linking > Type. In the Chart Linking window, both Time Zone and Symbol List are missing. Please take a look at this. Thank you. |
| [2026-04-06 03:14:50] |
| Sierra_Chart Engineering - Posts: 25489 |
We will go over this. We will make sure all the Chart Linking options are accessible in all locations where they are controlled from.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-04-06 04:08:09
| [2026-04-06 07:23:29] |
Thank you. I forgot to mention that Master Mode is also missing in the other locations. I hope you noticed that.
