Date/Time: Thu, 26 Nov 2026 04:01:28 +0000
Data Feed Stuck at 08:14 bar (3min chart) on CME data
View Count: 700
[2026-04-03 14:18:38]
AlgoAlpha_1 - Posts: 10
I am seeing CME futures data frozen at exactly 08:14 CST.
This is occurring in Sierra Chart (Denali feed) and simultaneously on TradingView, with both platforms stuck at the same timestamp.
This does not appear to be a local configuration issue given the cross-platform synchronization of the freeze.
Can you confirm whether there is a current issue with CME data distribution or Denali feed ingestion?
[2026-04-03 14:27:53]
Multiple users (including myself) are experiencing CME data frozen at exactly 08:14 CST.
My charts will not update past this timestamp, and I am seeing identical reports on the support board with the same freeze time.
I am also observing the same timestamp freeze on TradingView, which suggests this is not a local configuration issue.
Can you confirm whether there is currently a Denali feed ingestion or upstream CME data issue affecting real-time updates?
[2026-04-03 14:36:01]
UPDATE: I went back and re-checked CME hours today and the Holiday (Good Friday) started at 08:15CST. I had seen somewhere that the hours were until 10:30 CST--my mistake and hopefully this helps some others on the board with same issue.
[2026-04-03 14:37:44]
I swear this said 10:30 CST the other day...I DID check...
https://www.cmegroup.com/trading-hours.html#tradeDate=2026-04-02
[2026-04-03 15:57:32]
User135243 - Posts: 337
CME index-futures closed at 8:15 am ET FX-futures and Bonds/Notes closed at 10:15 am ET
