Date/Time: Thu, 26 Nov 2026 03:53:33 +0000
Tick Grafiken Problemen
View Count: 257
| [2026-03-31 17:39:52] |
| eli733 - Posts: 13 |
Hallo Sierra Team , jedes mal , wenn ich Chartbook aufmachen , muss ich alles neu machen und Tick Size korrigieren. Im Anschluss , wenn ich Tick Size korregiere, mache ich SAVE as . Trotzdem beim nächsten Mal , wenn ich Chartbook aufmache , , muss ich wieder Tick Size korrigiere. Bitte um Ihre Hilfe . Danke !
Private File |
| [2026-03-31 17:41:15] |
From Google Translate: Hello Sierra Team, every time I open my Chartbook, I have to set everything up from scratch and correct the Tick Size. Afterward—once I have corrected the Tick Size—I use "Save As." Nevertheless, the next time I open the Chartbook, I have to correct the Tick Size all over again. I would appreciate your assistance. Thank you!
Are you not using a standard tick size, and you are having to change it from the standard to something else? Please tell us one symbol for which you are having this issue. And tell us what tick size is coming up when you open the chart and what tick size you are changing to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
