Date/Time: Tue, 13 Oct 2026 16:42:59 +0000
No Data for GCM26_FUT_COMEX (June Contract)
View Count: 263
| [2026-03-31 14:52:48] |
| nasaanasaa - Posts: 2 |
Hello, Thank you for your response. The issue is not about delayed data. When I select the June contract (GCM26_FUT_COMEX), the chart does not load properly and shows no data (empty chart). However, other contracts may load, but the June contract specifically has no data or does not work. How can I fix this issue so that I can use the correct active contract? Thank you. |
| [2026-03-31 15:07:40] |
| John - SC Support - Posts: 48189 |
GCM26_FUT_COMEX is an incorrect symbol. It should be GCM26_FUT_CME.
