Date/Time: Thu, 26 Nov 2026 03:53:24 +0000
Use Sierra Chart Instance Username And Password
View Count: 404
| [2026-03-31 14:21:02] |
| User512353 - Posts: 198 |
SC2891 Start SC Instance#1 In Instance#1: Global Settings >> Date/Trade Service Settings >> Main Settings >> Service Settings the service is then (read only): DTC - Sub Instance [trading] and in the Service Settings there are is a Yes/No field Use Sierra Chart Instance Username And Password with presumably related Username and Password fields. What are these fields used for?? I could not find these in the documentation. |
| [2026-04-01 21:00:31] |
| Sierra_Chart Engineering - Posts: 25489 |
This means that when the sub instance logs into the main instance of Sierra Chart the username and password that you have set on the main instance will be used to login.
| [2026-04-01 22:06:24] |
I do not understand this. When I created the Instance, the default was Use Sierra Chart Instance Username And Password = Yes and the Username and Password fields are empty. It still "Logs in" - whatever this means. If I set Use Sierra Chart Instance Username And Password = No also everything works. There seems to be no difference in behavior - at least nothing that I have observed. But maybe something is different somewhere under the hood. And since it is unknown, also the consequences are unknown - and potentially dangerous. So, what is the real meaning of this setting? |
| [2026-04-02 01:35:44] |
The meaning is as we described. In the main/server instance of Sierra Chart, set this to Yes: Global Settings >> Sierra Chart Server Settings >> DTC Protocol Server >> DTC Protocol Server >> Require Authentication Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
