Date/Time: Thu, 26 Nov 2026 03:53:23 +0000
four monitors and one chartbook displays four timescales
View Count: 314
| [2026-03-30 16:31:26] |
| Tynda_venom666 - Posts: 9 |
Hi, I have four monitors and one chartbook displays four timescales, e.g., oil. Can I set one chartbook to display, for example, the oil contract on two monitors, and the gold contract on two other monitors? Selecting one chartbook displays two securities on four monitors: two monitors for gold and two monitors for oil? Thank you for your reply. |
| [2026-03-30 21:37:09] |
We are not really understanding the underlying issue/question, as we do not know how you have your monitors setup. If your monitors are setup such that they are a single virtual monitor, then you can setup the windows however you like. If your monitors are setup so that they are separate desktops, then you would need to "Detach" a chart to move it to a specific window. Refer to the following: Window, CB and CW Menus: Detach/Attach Window (Window) We are working on the ability to have chartbooks separated from the main application, so you could have a chartbook on one monitor and another chartbook on another monitor. We can not say when this will be available, but it is currently under development. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
