Date/Time: Tue, 07 May 2024 03:57:59 +0000
Trade Management By Study does not seem to work
View Count: 3283
[2014-10-29 20:09:04] |
User80160 - Posts: 26 |
Yep it is moving. Thnx a lot
[2014-10-29 20:57:33] |
My order is canceled When i turn auto trading on: Trading Message from IB: Order Event Warning:Attribute 'Outside Regular Trading Hours' is ignored based on the order type and destination. PlaceOrder is now being processed.. Error Code: 2109. ServiceOrderID: 1258. | 2014-10-29 21:51:12 What is the solutions for this? |
[2014-10-29 21:04:40] |
This does not mean the order was canceled. The order was placed properly. It is just an informational message. If the order was actually canceled, then ask Interactive Brokers about the reason for this.
[2014-10-30 11:31:53] |
Goodmorning, I am testing the Trade management by study (kiwi trail, but it is weird in all the studies) . It is moving but very weird and i see no movement link with Kiwi studie or Ma i tested. Long: no movement, the order cancels all most immediately. I see in the message log that it place its order on 1 240 min, and 1 min? And it says short only and position is long (but in the setting it is on short) Chart: EUR.USD-CASH-IDEALPRO 1 Min #1 | Study: Trade Management by Study | Position Type is set to Short Only and position is Long. | 2014-10-30 11:12:50 Chart: EUR.USD-CASH-IDEALPRO 1 Min #5 | Study: Trade Management by Study | The found Stop/Target order is not in an Open state. | 2014-10-30 11:12:50 Chart: EUR.USD-CASH-IDEALPRO 240 Min #5 | Study: Trade Management by Study | The Stop/Target order has been modified. Internal Order ID: 8281. New Price: 1.281050 | 2014-10-30 11:12:50 Chart: EUR.USD-CASH-IDEALPRO 1 Min #5 | Study: Trade Management by Study | Time interval has not elapsed yet for 'Every N Seconds'. | 2014-10-30 11:12:50 Chart: EUR.USD-CASH-IDEALPRO 240 Min #5 | Study: Trade Management by Study | There is not a new price to modify the order to. | 2014-10-30 11:12:51 Chart: EUR.USD-CASH-IDEALPRO 240 Min #5 | Study: Trade Management by Study | Position is flat. | 2014-10-30 11:12:52 Chart: EUR.USD-CASH-IDEALPRO 1 Min #1 | Study: Trade Management by Study | Position is flat. | 2014-10-30 11:12:52 Chart: EUR.USD-CASH-IDEALPRO 1 Min #5 | Study: Trade Management by Study | Position is flat. | 2014-10-30 11:12:52 Short: (offset 30 ticks): a view seconds it stays at 30 ticks, then it moves very close the the price and stops out. And it says long only and position is short (but in the setting it is on short). Here i see only one timeframe Chart: USD.JPY-CASH-IDEALPRO 1 Min #6 | Study: Trade Management by Study | The Stop/Target order has been modified. Internal Order ID: 8358. New Price: 109.024998 | 2014-10-30 12:29:05 Chart: Kiwi's Trailing Stop | Study: Trade Management by Study | The found Stop/Target order is not in an Open state. | 2014-10-30 12:29:05 Chart: USD.JPY-CASH-IDEALPRO 1 Min #5 | Study: Trade Management by Study | Position Type is set to Long Only and position is Short. | 2014-10-30 12:29:05 Chart: USD.JPY-CASH-IDEALPRO 1 Min #6 | Study: Trade Management by Study | There is not a new price to modify the order to. | 2014-10-30 12:29:06 Chart: Kiwi's Trailing Stop | Study: Trade Management by Study | The Stop/Target order has been modified. Internal Order ID: 8358. New Price: 109.074998 | 2014-10-30 12:29:06 Chart: USD.JPY-CASH-IDEALPRO 1 Min #6 | Study: Trade Management by Study | Position is flat. | 2014-10-30 12:29:06 Chart: Kiwi's Trailing Stop | Study: Trade Management by Study | Position is flat. | 2014-10-30 12:29:06 Chart: USD.JPY-CASH-IDEALPRO 1 Min #5 | Study: Trade Management by Study | Position is flat. | 2014-10-30 12:29:06 |
[2014-10-30 15:55:34] |
Can some please answer the question above? Thanks
[2014-10-30 15:58:23] |
We have other higher priorities. General you cannot expect a rapid response on a subject like this.
[2014-10-30 20:42:42] |
I am waiting for your answer with patience. Do you think we can fix before the weekend? Cheers |
[2014-11-03 09:49:25] |
We do not see anything wrong at this point. And from our perspective it generally is really hard for us to help with a problem like you are describing unless we can see exactly what you are doing. In the latest release, we have added additional logging. Update to the latest prerelease. It is best to do testing using using Sierra Chart replay in order to have a more stable environment to analyze problems. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-11-03 09:51:24
[2014-11-05 17:37:35] |
I am still testing the Kiwi. There are some things, i will post them later. But in the meantime can you help me with this; I have an oco bracket or on one computer with IB. Then i close this computer an open the chart with an other computer; The stop and the limit are not showing. They are on IB but not on the Sierra chart. The only thing i see is the position line. What do i have to do to fix this? |
[2014-11-05 23:10:58] |
There are some things, i will post them later. Keep in mind, we have to be provided a very simple and clear example of an issue.The stop and the limit are not showing. Most likely this has to do with the Global Settings >> Data/Trade Service Settings >>Connection Details >> Instance setting not matching between installations of Sierra Chart.Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-03 19:58:17] |
Hello People of Sierra Chart. I see the orders now. Thnx I made the trade on an other computer. But the Trade Management by study does not react: Study: Trade Management by Study | There is no Stop/Target order found. | 2014-12-03 20:30:40 Studie on. Automated Trade on. Can you help me with this last question about this studie? For you info: I found that the other errors from this studie came from shared chart settings. |
[2014-12-03 22:16:57] |
The study will be searching for Attached Orders only. So you need to make sure there are Attached Orders which have a Open status for the Symbol and Trade Account. Here is information about Attached Orders: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-12-08 07:39:24] |
I am using attached orders. And It works fine when i open a new trade on my laptop. But when open a trade (IB) from my dekstop on my laptop the Studie does nothing.
[2014-12-08 08:34:13] |
Yes, this does make sense. The study can only control Target and Stop orders entered specifically from the copy of Sierra Chart where the study is being used from.
[2014-12-08 09:40:39] |
Ok. But i am using the studiy on both computers.
[2014-12-08 09:41:21] |
Same settings also
[2014-12-08 09:41:35] |
It is hard for us to comment further on this, without seeing exactly what you are doing.
[2014-12-08 09:45:59] |
What info do you need? I like to make a trade. Trail it with Kiwi. Open it on an other computer. And go on trailing it. That is it. Can this be done? How? |
[2014-12-08 11:53:13] |
Is there (maybe) tomorrow time to fix this?
[2014-12-08 16:42:27] |
With what you describe in post #42, it is not possible to do this for the reason given in post #38.
