Date/Time: Thu, 26 Nov 2026 03:53:36 +0000
JFI on Socket
View Count: 296
| [2026-03-30 10:36:15] |
| User731023 - Posts: 167 |
There was a message from IB TWS that for whatever reason they disabled Socket? Something about their obligation to let be known? Or something like that. Anyway, I had to go to TWS and enable socket under configuration to get Sierra to work. |
| [2026-03-30 15:36:01] |
It is in our Setup Instructions for Interactive Brokers that that item needs to enabled. See Step #5 at the following link: Interactive Brokers Trading Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2026-03-30 15:36:26
| [2026-03-30 18:11:00] |
Thanks. It was already checked before. That was just to let you know that IB sent out a message that was for compliance reasons and unchecked it. I just had to go an enable it again My post was just let you you guys know about it in case it happens to someone else. |
| [2026-03-31 13:47:33] |
Thank you for letting us know. Very odd that they had to undo that for some reason.
