Date/Time: Thu, 26 Nov 2026 04:01:32 +0000
Color Settings for the Active Control Bar Button - [Feature Request]
View Count: 490
| [2026-03-30 09:21:57] |
| Daniel - Backtesting.club - Posts: 177 |
Hello, Could you please add an option to set the color of the active (depressed/selected) button? Currently, Sierra Chart uses a cross-hatched pattern for active buttons. However, as you can see in the screenshot, this doesn't work well when the button has light-colored text — the text becomes very hard or impossible to read. If possible, being able to set the active button color (ideally both globally and per-button) would solve the issue nicely. We could then choose a darker shade that keeps good contrast with the text. If that's too complex to implement, could you at least give us control over the second color used in the cross-hatch pattern? If even that isn't feasible, I'd appreciate any other solution you can suggest. The active buttons are really difficult to read with light text colors. Thank you! |
| [2026-04-02 17:32:55] |
Could you please let me know what your position is on this issue? Thank you.
| [2026-04-02 17:45:49] |
We have noted this as a Feature Request. We can not say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
